Wow, that is a relief. thanks!
don |
Good job on the writeup and pics of the plugs etc. I did this combined with the guitar string method that amfab over at rennlist pioneered. Had two ports number 3 and 6 with no airflow. After drilling and flushing they opened right up.
Stan
Stan D |
I bought an extra one.. (if you need one I'll sell it)
Jascha 1989 911 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Does anyone know if any corrective actions were taken during dealership rebuilds for SAI issues, that would lessen the likelihood of this issue reoccurring?
One of the receipts from my car's past shows a cylinder head rebuild due to plugged passages. The documentation includes a comment stating: "Drill Secondary Air Passages" What was the extent of the 'drilling' operation performed? This was a warranty repair @ a dealer. |
"What was the extent of the 'drilling' operation performed?"
This implies that the air passages were cleaned by use of a drill and a flexible wire/cable, e.g. speedo cable, to fully remove the carbon buildup, which is the common technique used.
Have Fun Loren Systems Consulting Automotive Electronics www.systemsc.com '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
If it flows, it goes. If its smooth, it moves...Any questions? You can either get busy living, or get busy dying. 85 911 Factory Turbo-Look Targa (Totaled) 87 911 Factory Turbo-Look Cab (Sold) 96 993 C2 (Current) |
Air leaks into the exhaust due to failed plugs or check valve can cause other problems & should be addressed even if a check engine light is not present. (lean shift in o2 sensor readings, elevated catalyst temperatures, interaction with o2 sensor diagnostics, etc..) Rebuilt manifold: ![]() Here's another potential failure point that hasn't been discussed: ![]() ![]() |
