Phase 5, Done
Phase 1, RS Aerokit
Phase 2, RS brakes Phase 3, G50/30 Cup transmission Phase 4, Full JIC Comp suspension, TRG adjustable bars, lowered, corner balanced, Unbelieveable handling Phase 5, 3.8RS installed in '95 coupe ;) http://forums.pelicanparts.com/uploa...1173802963.jpg http://forums.pelicanparts.com/uploa...1173802984.jpg http://forums.pelicanparts.com/uploa...1173802998.jpg http://forums.pelicanparts.com/uploa...1173803018.jpg http://forums.pelicanparts.com/uploa...1173803042.jpg http://forums.pelicanparts.com/uploa...1173803063.jpg http://forums.pelicanparts.com/uploa...1173803087.jpg Weather finally broke, finally got a chance to play w/ phase 5, Ausgezeichnet!! |
Sweet
nice work Bill.
But, but , but ... it has AC in it! You figure the 3.8 has the extra power to run it in a race too? :) Thank god the class rules prevent me from doing a 3.8. I have to live with a 300 hp putt-putt rthat's a bit over-weight.
It looks great. Our 70's and sun have made me yearn for track dates and I have to wait another couple weeks before getting back out again. |
WOW! I'd love to go for a ride one day...
...or maybe it would be a lot better for my wallet if I didn't. |
looks like the heater blower has been removed though. nice, bill. :)
nice bill :)
I need a /30 for my car |
solid lifters?
drop me an email Bill, have some pics of a Timmons based exhaust I did to share with you.
was there any difference between hydraulics? were they all the same part number? I see to have damaged mine by running 15/50 oil. I have lifter tap, no too bad, but enough to be annoying.
there are 3 lengths of hyd. lifter. The longer ones are only used if the valves seats are moved from the standard stock position possibly be a valve job or seat replacement.
15/50 shouldn't have caused an issue. They are wear parts w/ the polymer seals being the most fragile parts |
Fantastic! Nice work. IMO Your car is the ultimate especially the color.
thanks Bill. the way Tyson built the engine, we ran ti springs, etc. we had the heads done with valve angle and guides. I replaced all the lifters and within 3,000 miles I have noticable lifter tap, when I listen to other 993 engines I don't hear this noise. I am driving it now with 0w40. What do you think would be the right one to run? I even considering solids thats how much I want to address this issue.
993.105.141.05 is stock
993.105.141.51 is size 1 993.105.141.61 is size 2 Stock intake spring height for an M64/05 - 08 is 36.7 +0.3mm, exhaust is 35.7+0.3mm which version you need depends on the difference your spring height is from stock I don't know the actual length of any of them, You will need to find that out and choose acordingly. |
thanks Bill. I will find out the height of mine and see what this means. Big help, I appreciate it.
Could we have more pictures of you car? Exterior shots would also be nice... Are those original Speedline for Porsche wheels?
Incredible car and cool color, Bill. |
