164k on my clock. black, 1990 964 C4 cab with excellent history going back to origin for every major service, which included a couple of engine drops, all necessary upgrades including cylinders to head seals, dual dizzy vent kit, dual-mass flywheel replacement, etc. plus routine maintenance. two months of ownership and hasn't dripped a drop on my carport floor. anyone with higher or similar (s)miles?
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
nobody with more? okay..guess i win!
Wow, 164k miles. Is this on original P&Cs?
Did the PO replace or just had the cylinders remachined to accept the head and base seals? What about valve guides? I have 84k on mine but it's a 1993. 1 quart oil every 2000 miles. I fixed all the oil leaks myself. Power steering, oil return line to case seal, oil drain seal and oil pressure sensor o-ring. Replaced the fan/alt belts, dizzy belt and replaced voltage regulator. Also replaced the clutch master cylinder lately and that's about it. I only spent about $400 in parts over two years to get it to where I can drive it daily. I wonder how long the original clutch and valve guides/seals will last. Will my clutch last 150k? We'll see. I don't ride the clutch and always match revs when up and downshifting. I hope to drive it up to 150k miles on original engine and clutch.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
90 C4 with 209k OEM drip drip drip motor, but runs strong especially after new dizzy, plug wires and coils. Rebuild/reseal was planned for her sweet 16, but.....
bazar...it did have a top overhaul with new valve guides. i'll need to check again to see if cylinders were redone or replaced.
colo964...you're in the lead, buddy! ![]() ryan
168K on stock engine.
It is now apart getting some leaks fixed. Runs strong...264 RWHP |
closing in on you fast, chin..
damn..i'm in third place now!
bigchill, sad thing is I'm probably in 10th place to start with. We're teeing off from the ladies tees.
180,000 + on a 1992 C-2. Oh and the odo is broken right now, replacement is on the way. Wife drives it everyday as did the PO. Apart right now fixing oil leak on the line from the filter assembly to the T'stat which turned into a tank replacement. Actually needs top end which will happen soon but with her driving it should go a bit longer before absolutely necessary.
'79 SC has about same mileage. Cool weather daily driver for me.
Kevin '79 Coupe |
4th place now..
lol. yeah, i hear ya colo, but would love to hear of those nine higher than yours.
Its an 84 but I have 191.600, engine never opened as far as I know,no leaks.
84 911 Carrera SOLD not forgotten 01 911 C4 factory Aerokit ![]() 76 914 rust bucket SOLD !! 03 Boxster S sold 98 944 S2 G Red,sold 04 FRC red Vette |
89 c4 with 159,000 miles
1989 C4 Coupe 1975 911 carrera 2.7rs Sold 1978 911sc Sold 2001 Boxster S |
any others?
woah...i think i saw a 270k car on the rennlist thread.
98k...I've GOT to get busy!
1996 FJ80. |
hurry, up seahawk..don't get left behind!
For you guys with high mileage engines, what grade and brand of oil has the engine historically been using ?
I have 220K miles on the original engine on a daily driver (90 C4 Cab). I'm running Mobil 1 15W-50 and change it once a year.
Rob ------ '90 964 Cabrio - daily driver 220K miles |
cool, rob. you like the synthetic in a higher miles car? no leaks? i'm about to do my first change in my new to me 964 C4 cab. i'll be using castrol 20w50 as always for summer in all my p-cars..
