P1126 Code
Thanks. I pulled the codes and got P1126 aka the throttle position sensor. Now what?
The code 1126 indicates that the DME ECM has attempted to correct
for an over rich fuel mixture and has reached its limit. Check: 1. fuel pressure 2. MAF sensor |
But the tech. service bullletin says it's a lean condition issue and suggests something back there ain't tight and is letting too much air in.
Rick - I pulled this out of the SAI CEL thread into a new thread for your specific problem.
| All times are GMT -8. The time now is 07:27 AM. |
