Bland
unclebilly's Avatar
Hunting Idle
Hi Guys,
My idle hunts once my car warms up. Often it stalls at lights. When it does idle, it idles around 600 RPM.
My guess is the O2 sensor (it doesn't do it when cold in open loop mode) and it doesn't do it all the time - just 75% of the time.
Thoughts? I don't want to spend $150 on an O2 sensor if I don't need one.
Otherwise this car runs awesome and the plugs all looked awesome when I changed them recently.
Scott.
Old 04-25-2007, 07:16 PM
Bland
unclebilly's Avatar
I thought I would add that this condition didn't change with new caps and rotors, new spark plugs, new air filter, and valve adjustment.
I do have a durametric - will this help me diagnose this problem?
Old 04-25-2007, 07:43 PM
Don Plumley's Avatar
Have you cleaned the ISV?
I don't know enough about OBD1 and the Durametric tool, but in theory it should allow you to watch the O2 sensor to make sure it is okay.
Don Plumley
M235i
Old 04-25-2007, 09:01 PM
Bland
unclebilly's Avatar
I have not cleanedthe ISV - what is involved here?
Old 04-25-2007, 10:12 PM
Not sure where it exactly is on a 964 motor, but this is a good place to start:
http://p-car.com/diy/isv/
Don Plumley
M235i
Old 04-25-2007, 10:18 PM
bigchillcar's Avatar
it's easy to clean. it's a silver canister on top of the motor held on by a cpl hose clamp and two hoses that run into either side as i recall, and there's one plug to disconnect. it's about 4 inches long and 3 inches wide, cylindrically-shapped, above the intake. anyway, you spray it out thoroughly with brake cleaner over and over until black gunk quits coming out. give it a final wipe inside as best you can reach with a paper towel and re-install. maybe a half hour job if you take your time.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 04-26-2007, 07:25 AM
Bland
unclebilly's Avatar
This seemed to improve things considerably. Thanks for this suggestion.
Old 04-26-2007, 07:38 PM
glad to hear it. you're welcome.
Old 04-26-2007, 08:51 PM
you might also want to check to see that the idle control microswitch is being depressed fully. earlier this year i had low idle, and occasional stalling. it turned out that i had to adjust the throttle cable about 1 mm so that the microswitch depressed fully. ----tom
Old 04-30-2007, 12:27 PM
Tom has got it. That micro-switch issue is not that uncommon.
When the switch is not being depressed by the throttle linkage the computer believes that the gas pedal is being pressed so it does not control the idle.
This is the most likely culprit when the car lops at idle, but works perfectly whenever you are on the gas.
All the best.
BG
1990 C4
Old 04-30-2007, 06:11 PM
P-Zero Burner
911Urge's Avatar
+1 on the idle micro switch. One last thing to clean (since you did the ISV) is the Air Flow Meter (AFM).
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 05-03-2007, 11:13 PM
Bland
unclebilly's Avatar
I checked the microswitch last night and it seemed as though it was being fullydepressed.
There were no motronic codes at all.
Then I stsrted the car and fiddled with the throttle / mictoswitch and it threw an 02 sensor code. This is wierd because there we no 02 sensor codes stored in memory.
Old 05-05-2007, 07:28 AM
My idle was also fluctuating (ltwo years ago when I got the car) between 850 and 1000 rpm.
Disconnected the microswitch connectors and check for continuity and was barely making.
Disconnected the battery, put some slack by adjusting the throttle cable so the idle switch makes, reconnected the batery, it's rock steady since then.
Not sure if the battery reset or the microswitch adjustment fixed it.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-05-2007, 10:41 AM
any pics of where the microswitch is located? got me wanting to check my own..
Old 05-05-2007, 01:03 PM
The connector is right beside the Idle air control valve.
Here is the pin assignments.
Idle microswitch should be closed or zero resistance when in idle.
Old 05-05-2007, 02:58 PM
gotcha. what am i checking for exactly? i can disconnect it and reconnect. is that all you're saying to try? of course, i have a lightweight flywheel, which probably explains my funky idle...but i've got a new issue i posted on the 964/993 forum here last night, too..
thanks for taking the time to post those pics, bazar. i really appreciate that.
Old 05-05-2007, 06:23 PM
You may want to hook up a multi-meter on the terminlas noted.
Meter set to continuity or resistance.
Put one probe on the idle contact terminal and another probe on the common terminal.
You should get continuity or almost zero ohms when throttle cable at idle position.
When you lift off idle, it should go to high resistance.
Old 05-06-2007, 04:48 AM
thank you, bazar. i follow you now..and adjustments are made on the throttle cable.
Old 05-06-2007, 07:50 AM
