DCopestakes's Avatar
95 993 Cabriolet Top Adjustment
My 95 C2's Cabriolet top started jamming and I chose to try adjusting the vertical and horizontal adjustments behind the rear speakers. Perhaps that was a bad idea. I can make it worse but no better. I took it to the dealer and found there is a recall that replaces the motors at the front latches and they will do that no charge. However, they want to replace the transmissions at a cost of $1700. I can't quite wrap my mind around that one as I believe I caused the problem by maladjusting the roof myself.
Question: Does anyone know of a manual or procedure that will show me how to correctly adjust the roof?
Thank you
Old 04-29-2007, 03:21 AM
AFJuvat's Avatar
Do a search, I have covered this extensively in the past.
Short answer, the drive cables break, and then the transmissions get damaged.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-29-2007, 05:52 AM
Sports Purpose 911 Driver
mjshira's Avatar
you could switch to a manual top for around the same money or less and avoid future issues. adjustment of the top is a tough job. take your time.
James Shira R Gruppe # 271
1972 911 Coupe ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe Emory build in waiting
1957 356A Emory speedster build in progress
Old 04-29-2007, 06:49 AM
I gave up on mine and removed the motor, drive cables and both gear assemblies. now I just put up the top manually and use the latching motor to grab the top and pull it in.
Old 04-29-2007, 04:43 PM
notfarnow's Avatar
I've seen your posts on electrical sequences, but I didn't have any luck finding any posts that cover the mechanical ajustments of the top.
'03 Carrera 4s
'00 4Runner / '85 LeCar / '88 Iltis
+ a whole bunch of boats
Old 04-30-2007, 05:55 AM
