install 964 suspension on 993 question
I am going to install a set of Koni's and Eibach springs fom 1994 964 to a 1995 993.
The Koni's # 8241-1104 Sport, 9304 and # 8741-1216L Sport.
The Eibach # 16/94, 7201.002 and # 17/94, 7201.001
I also attached the picture of the suspension.
Is it possible to install the suspension to a 993 ?
I think the front suspension will be no problem, am i right ?
But the rear suspension, i have to modify or make the sway bar mounting as the rear shock of 964 doesn't have it ?
Can i reuse the other hardware from the OEM 993 to the 964 suspension (spring perch, upper mount, etc) ?
Thanks.
Old 04-28-2007, 08:33 PM
Banned
Fronts, straight install, no problem, rears, you are better off with the 993 set up, which KONI doesn't produce, Candy.
Old 04-29-2007, 08:29 AM
Agent Orange
ilko's Avatar
The 993 has a completely different rear geometry, so the setup you have won't work at all. You're better off selling it and getting something 993-specific.
Old 04-30-2007, 09:32 AM
