Jaz Jaz is offline
Jaz's Avatar
need buying advise and tips for a 964
HI Guys, Though mechanically minded and not to shy do my own repairs (VW Golf owner) I'm relatively new to porsche scene and about to embark upon the purchase of a 1991 964 Carerra 2 with 90,000 miles on the clock.
Could you give me some tips as to what I need to look for interms minimising surprises & repair bills :
modification/rectifications ie stainless steel exhaustr heat exchangers
engine functions ie idle speeds, oil leaks or tensioners, etc.
Any buying tip info would be very much appreciated.
Regards,
Jaz
http://www.juswant.btinternet.co.uk
Old 05-02-2007, 02:23 AM
Agent Orange
ilko's Avatar
Do a search on this forum as well as http://forums.rennlist.com/rennforums/forumdisplay.php?f=59
Also check out http://www.porsche964.co.uk/ - there is a buyer's guide there.
Good luck and have fun with the new ride!
Old 05-02-2007, 06:51 AM
aeroman's Avatar
Make sure it has had 60K and 90K service or you are going to be out 2K right from the get go. Also look for last time the valves were adjusted.
1992 Carerra C4
Old 05-02-2007, 11:04 AM
Jaz Jaz is offline
Jaz's Avatar
serving the 964 - access problems
Thanks Guys,
I've regularly serviced my own cars, would the 964 be an easy DIY serviceable car? I hear that you have to dismantle the exhaust and various other parts to access spark plugs. Is access for an oil change and oil filter easy.
Cheers, Jaz
Old 05-03-2007, 05:48 AM
Agent Orange
ilko's Avatar
The exhaust and heat exchangers are not difficult to uninstall. The oil change is easy, the filter is on the right side in the engine bay, very easy to access.
Old 05-03-2007, 06:37 AM
Jaz Jaz is offline
Jaz's Avatar
Thanks,
Then I can I be confident in knowing the 964 will be an easy car to do DIY servicing on ?
Regards,
Jaz
Old 05-03-2007, 07:54 AM
Agent Orange
ilko's Avatar
http://p-car.com/diy/diy.html - it's for a 993, but the majority of the info is identical for a 964.
Old 05-03-2007, 07:56 AM
bigchillcar's Avatar
90-91 models came without cylinders to head seals. some cars leaked badly while others not a drop. many cars have had the seals added by now. find out what flywheel they have..mine had the original often problematic dual-mass replaced with a lightweight. dual dizzy needs a vent kit installed to protect its belt from ozone (cheap part, btw). check EVERYTHING on the climate control. the main unit can fail or the servos that control everything as opposed to the old cable controls ($$). 964's are a lot of fun..just a little more complex, particularly in the electrical department than prior 911's.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-03-2007, 01:35 PM
