-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Need info about 996 engines..... (http://forums.pelicanparts.com/porsche-964-993-technical-forum/344846-need-info-about-996-engines.html)
Ed scuba 05-04-2007 12:26 PM
I was at metal scrap yard weighing my car 2450 lbs.. Guy told me to go see mechanic as they have a Porsche engine in a shed. Turns out to be a 996 3.4L. "I think it was running when removed from wreck". "I think they'll sell it for a couple of hundred"
Can this fit in my 1984 911?
What's it worth for resale or parts?
Also looks like front wheel drive case? Or rear differental?
Engine # is 9961041391R3.4L
# on Case 70D0263921G and also decal that has 4WD 1.211 ratio.
Think case is Porsche part?
Any info on this would be helpful. Thanks
Ed scuba 05-04-2007 01:00 PM
Sorry wrong board.
kang 05-04-2007 01:06 PM
It's worth a lot more than a couple hundred, that's for sure.
Don Plumley 05-04-2007 01:29 PM
Could it fit in your car? Yes. Should you do it? No - you'd have to figure out new mounting, Water cooling, etc. Just like your car, there are no rear differentials (standard transaxle), but if it came off a C4, it would have a front differential. Which then requires high pressure hydraulics...
To which board to you want me to move this post?
Ed scuba 05-04-2007 01:38 PM
Thanks for info. I reposted to 996 board thanks.
