Bilstein PSS9 II - need help with setup.
I'm in a bit of a bind. I got PSS9 Gen II installed on my 993 C4 last week. Driving to Vermont I realized I have a problem. Ride height is way too low. I have damping rate set to 5, but still have right reat tire rubbing fender. Height seems lower at that corner. I can stiffen it further if necessary. But (now that I'm in Vermont) I'd rather get a local to adjust ride height up a bit. But I don't have Bilstein's PSS9 Gen II manual. I can't find it ANYWHERE on the internet. Does anyone know where its posted? Can someone scan and post or eMail to me?
Thanks in advance for any assist! JD |
Check over on forums.rennlist.com, they have a much more active 993 forum, you might get a quick answer to your question. Also, try the "search" feature, it might have already been posted before.
Good luck. |
Here's a great DIY from a rennlist member: http://forums.rennlist.com/rennforums/showthread.php?t=258810
When you say it's rubbing the fender, I think you simply need to roll the fender. Get a baseball bat and start rolling! |
| All times are GMT -8. The time now is 07:18 AM. |
