water question
Yesterday as I washed my 964 -90, I noticed that I have water in the right hand side footwell under the carpets. Any ideas, as other carpets were dry and the car has been inside for 5 months. The car is equipped with sunroof.
Kris
KH
964 C2 -90
9-3 1.8t -06
sold
911 3.2 -74
Old 05-21-2007, 11:45 PM
kurquhart's Avatar
Unfortunately, that is fairly common. It could be the sunroof seal, blocked sunroof drain tube, window seal, or even the windshield seal. Some careful squirting with a water bottle should turn up the culprit.
If the carpet is wet, the foam pad underneath is probably saturated. Try to squeeze the water out of the foam and let it dry out of the car.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 05-22-2007, 07:41 AM
