-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   anyone know why my 964 is shutting down while im driving (http://forums.pelicanparts.com/porsche-964-993-technical-forum/348982-anyone-know-why-my-964-shutting-down-while-im-driving.html)
shane_c 05-28-2007 01:17 PM
does anyone know why my 964 just stops for no apparent reason while im driving? its 1992 C2 tip. with 76000 miles. while im driving the system error light comes on and the car just dies completley. i can still turn it over to try and restart it but it wont fire for a few minutes. the same problem occurs if i stop after driving for a bit and try to restart it straight away. it wont. again it'll a few minutes to fire. problems also happens if you repeatedly start and switch off the car. after a couple of cycles it will refuse to start. im lost but ive ruled out the alarm as ive had it checked. any help or idea's?????????
Don Plumley 05-28-2007 01:46 PM
DME Relay?
puma1824 05-28-2007 01:50 PM
Try cleaning the ISV...that worked for me. (if it's not the DME Relay)
Proceedure LINK
ISV:
http://deleos.com/gallery/albums/964...ICV2_Small.jpg
http://deleos.com/gallery/albums/964...ICV3_Small.jpg
unclebilly 05-28-2007 07:23 PM
Dirty battery connection? Does the clock or radio reset?
ekessel 05-28-2007 07:51 PM
Replace the DME relay. It goes bad, and you lose the fuel pump randomly........
shane_c 06-02-2007 03:46 PM
thanks folks replaced the dme relay on thursday and i haven't had any problems since. all the advice is much appreciated. cheers!
bigchillcar 06-03-2007 08:21 PM
hmmm..i may be doing this very soon. my '90 C4 has been losing power intermittently, like it's suddenly not getting fuel for a few seconds, sometimes longer, then it comes back. it hasn't stranded me - yet. but i do have a new dme relay in the car should this turn out to be my car's problem.
tbennett017 06-05-2007 02:25 PM
It is a good idea to keep a spare handy in the trunk.. I have mine taped to the inside of the relay box...ready to go in an emergency.. do yourself a favor and get one... ;-)
Don Plumley 06-05-2007 08:00 PM
My trick is to buy a new DME relay, install it, put the old one in the glovebox...
bigchillcar 06-05-2007 09:45 PM
it's really getting time for me to do this. it must be intermittently shutting off the fuel pump. it feels like it's not getting gas or only a little. it responds to more pedal pressure, but until 'it passes', you're only going to get so much. make me do it! i have one in the glove box..brand new and ready to go!
colo964 06-06-2007 08:22 AM
Your fuel pump might be going, too. Mine was cutting out for a few weeks then totally conked out. Luckily it was on Mulholland Drive, not the 405. Relays are cheapish and are wear items so put the new one in - it might do the trick. Fuel pumps are easier to replace than the trouble a bad one might land you in, mine died at 147,000 miles. I've got 63,000 on the new (6yrs old, now) pump, hope to get another 50k out of it.
bigchillcar 06-06-2007 08:31 AM
thanks, colo964...i hope it's the relay. anyone know an easy way to distinguish between the pump and relay being the culprit?
kurquhart 06-06-2007 08:39 AM
Simple: change the relay and go for a drive. :) This is a 30-second swap of a $30 part - as cheap and easy as they come.
bigchillcar 06-06-2007 08:43 AM
hi kris, i've thought of that, but the problem is so intermittent..sometimes a couple days pass between issues. but i guess if it didn't come back after days on end..i'd know. :)
