brake accumulator,,where is location of bleed valve???
bleeding/changing fluid in my system,,found the brake accumulator on my 1992 964 turbo but cant find the bleeder valve on it,,can anybody tell me where it is or what it looks like????aaaah!!...help!!
Old 05-30-2007, 11:37 AM
Bill Verburg's Avatar
If you don't have a shop manual, get one. There can be 180bar of residual pressure in the system you are playing w/ dynomite.
Bill Verburg
Old 05-30-2007, 11:55 AM
yeah ive got a shop manual but i cant see where the bleed valve is on the drawing or the accumulator itself????,,need to know where the bleed valve is so i can bleed when changing the fluid!..here is a picture below to see if anyone knows how to bleed??..this sits in the front luggage comp nearest the bumper side
Old 05-30-2007, 01:13 PM
In your manual section 47
p47-11 thu-29
Everything is in the trunk around the spare tire
Bill Verburg
Old 05-30-2007, 01:53 PM
facing back look to the left rear of the spare, see the bomb?
Bill Verburg
Old 05-30-2007, 01:55 PM
AFJuvat's Avatar
WARNING: pressures of up to 180 bar are present at the accumulator.
Follow workshop instructions exactly.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-31-2007, 03:26 AM
found that bomb!!...lol...got it,,,cheers guys
Old 05-31-2007, 08:06 AM
fastfredracing's Avatar
Very interesting, anybody have any insight on how this is bled, I have to replace the one steel line that is shown in the picture, as there was a small battery fire on the car I am working on right now.
1976 930( peru red usa) ,1980 euro sc, 1974 914. 1997 M3, , 2004 Duramax 3500 quad cab dually . 2004 2500 HD Gas 1989 Yamaha xt 350. 2004 Turbo Pepperwagon, 1976 Chevrolet C 60 Rollback towtruck. 2006 x3 a few old tractors, and tons of tools
Old 05-31-2007, 04:30 PM
AFJuvat's Avatar
Essentially, you charge the accumulator and then disconnect power to the ABS pump. Then you bleed at the accumulator. Close the bleeder valve, and then start the ABS pump to recharge.
Some method of securing the bleeder hose to the valve is recommended. I always had luck with using silicone hose and securing it with a zip-tie.
Old 06-01-2007, 04:41 AM
