Send a message via Skype™ to machisono
Rear axle bearing problem c2 1991
I'm hearing clunking noise from rear suspension going over minor road bumps, just changed the front and rear shocks and noise persists. Some movement in the rear bearing assemblies but we don't think it could cause that much noise.
Thanks in advance.
Old 09-28-2007, 12:09 PM
Bad bearings will not cause a clunk. More like wub-wub-wub noises.
Rear upper and lower shock mount bushings are tight?
You may want to inspect the park brake shoes inside the rotors.
Something had came loose.
Good luck.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-28-2007, 01:02 PM
