Mammalian
Air box up-grade. Opinions.
What are your experiences with a particular airbox up-grade?
Factory Motorsound, Fabspeed, Etc.. Any increase in HP? or just better sound?
1973 914 2.0 2007 Cayman |
HP increase? I really doubt it. The drilled cover does sound better (louder) at wide open throttle.
Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) |
the drilled cover does sound GREAT!!!! i just did it..... it gives about 25 "EAR" wheel horsepower......DAMN does it sound good!!
I have the fabspeed cup box and RMB sounds great but I doubt it helps with power. It might open up some mid range response but negligible at best. Did I mention it sounds great.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Definitely a nice sound increase. You don't neeed to buy an aftermarket cover, just drill out the airbox yourself. I have approx. 20 1" holes in mine.
Mammalian
I'm going to try and find a stock airbox, or at least the cover. And drill the holes.
I've looked on eBay, but none right now. If anyone has one or see's one, give me a holler.
call dcAutomotive at 252-977-1430 and order it from them
Cobalt....what is an RMB? thanks
Sorry "Rear Muffler Bypass" also known as G pipe.
is that the little "C" looking pipe? is it loud?
Yes it is. It is louder than stock but sounds great. Has a nice growl and sounds like it should IMO. It does not resonate like some after market exhausts and is legal even at Lime Rock by a fair amount.
is it tough to install?
Easy as they get unless the bolts are rusted solid maybe an hour. Once you have done one maybe 25 min. It also saves 25-30 pounds off the rear end.
i guess just loosen the bolts that hold the muffler on and replace it with the pipe? is the muffler on the passenger side?
I know it is a bit basic but once your under there it will become clear.
thanks!!
Mammalian
Drilled out the Air box today similar to these pics. Very nice sound boost. Not much more than that.
Thanks everyone for the advice and feedback. ![]() ![]()
i have the k&n air filter..does the same thing..more growl.
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
It has been documented that drilling the top cover of the airbox does increase the engine's output by 6-8HP in a 993 engine. Bruce Anderson reference. The stock opening where the air goes into the filter is a bit restrictive and the engine has more volumetric efficiency that is achieved by giving the intake more holes to suck air into the engine. The HP claims from K&N and others are mythical in the 964 and 3.2L engines which are restricted by the older barn-door air flow sensor intake after the air-filter intake. Those airbox holes only make more noise and probably has no increased in HP (unless chipped).
don't know of any horsepower gain from the k&n air fllter in my 964 (car is cyntex chipped), but the sound is very nice with it. if that's the only benefit i'm okay with it, and it likely is.
