Screen washer jet
When I use the screen washer
(off steering column)
it continues to jet/dribble water onto the screen, long after the switch is released.
would that be something on the stalk playing up electrically,
or a problem in the plastic plumbing itself
Nineteen Ninety One 964
Old 10-06-2007, 01:25 PM
Don Plumley's Avatar
After looking at the PET on this, there appear to be four valves, 2 each side, in your system to prevent this leakage. I vote plumbing problem.
Don Plumley
M235i
Old 10-07-2007, 02:51 PM
You couldn't describe layout in a bit more detail I suppose could you
Richard
Old 10-07-2007, 03:02 PM
PM me your email address and I'll send it to you.
Don Plumley
M235i
Old 10-07-2007, 05:22 PM
The culprits then would appear to be
items
9
10
a couple of valves in the principal washer circuit,
but what is likely happening, I suppose what I mean is, with no power pumping water through circuit, what is producing pressure to cause this leak/dribble,
and how do these valves fit in please
thanks
Old 10-11-2007, 01:49 PM
The circuit has pressure in it from the pump. I presume if the check valves have failed, then fluid can dribble out - there's also a small venturi effect on the nozzles I assume.
As you can see in the PET, all the hoses are held on the barbs by small clamps (17).
Don Plumley
M235i
Old 10-11-2007, 02:13 PM
Anyway Don
they look the most likely and cheapest first repair option,
out of interest though, what might have occured to make BOTH fail
and how might I test each of them individually
er
do pelican sell them as well
cheers
Old 10-11-2007, 02:54 PM
