-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   993 gearbox question (http://forums.pelicanparts.com/porsche-964-993-technical-forum/370711-993-gearbox-question.html)
brit911 10-06-2007 01:02 PM
993 gearbox adjustment/linkage question
Please help!
I have a 993 C2 non VR which I'm having problems with the gearchange. Its as if when selecting 3rd I have to move the gear lever over to the left slightly, I have changed the front lever parts which showed the pin was bent, is there any adjustment or should i change the rod from the lever to the gearbox? any help appreciated.
Cheers
Don Plumley 10-07-2007 11:23 AM
Do you have any pictures? What caused the "pin was bent"? Perhaps the rod was also slight bent with whatever caused the other damage?
