lazylongboarder's Avatar
How to convert 993 Turbo trans to 2wd
What is involved with converting a 993 turbo trans to a 2wd?
I've made a bunch of calls...guard transmission, motor meister, and a few others and have had some trouble getting a clear answer. Any articles or references?
I've also heard a rumor that all you need to do is switch the nose-cone to a C2 nose-cone.
Thanks, Russell
Old 10-14-2007, 05:51 PM
The easiest way is to remove the front cover, remove the VC, then replace the cover with that of a C2. Not hard at all.
Old 10-14-2007, 06:59 PM
Big write up on rennlist.com under 993Turbo search (2WD conversion) viperbob in tampa sells a kit out the door for your car.
Old 10-14-2007, 07:20 PM
woo! great news! I just put 550 hp in my 90 c2, haven't even driven it yet only cause i'm afraid of the stock open diff g50/03 in the car letting go.
Thanks guys.
Old 10-14-2007, 10:44 PM
Geary's Avatar
The pinion extension is cut off, and a front housing (nosecone) from a 993 is installed.
Old 10-15-2007, 12:51 PM
