speed sensor
can someone please tell me how to get my speedometer to work.where is the speed sensor.and how can i check it.The dealer told me it s the front wheel sensor.is that true.if that's the case,what s the resistance,or voltage on that sensor
Hopefully this will help you out?
Cheers, http://forums.pelicanparts.com/uploa...1192304204.jpg http://forums.pelicanparts.com/uploa...1192304245.jpg Scanned from "993 - The Essential Companion" Author: Adrian Streather http://forums.pelicanparts.com/uploa...1192304352.jpg |
This is the engine speed reference sensor for the DME. It has nothing to do w/ the speedometer
http://forums.pelicanparts.com/uploa...1192304245.jpg The speedometer signal comes from the toothed gear on the back of the front hubs, also used be ABS http://forums.pelicanparts.com/uploa...1192304662.jpg |
thanxxx guys .it reads it from the wheel sensor,i know that.Does anybody have the diagnostics for that?
| All times are GMT -8. The time now is 04:57 PM. |
