! and ABS warning light
My ! (idiot?) light and ABS light illuminate at start up and go off after several minutes of driving. The ! light can be turned off quicker manually, but the ABS light stays on for approximately 5 minutes.
This all started after I had removed the battery to charge and clean the battery box during 60k tune up activity late last year. I've tolerated this for a while but would like to fix it.
Did a search and one method that might be promising is to disconnect the battery for 30 minutes or overnight then run to warm, shut down and restart.
Otherwise it sounds as if my codes need checking. Suggestions?
I also get a ! and ABD light when using fog lights. This was previously diagnosed as bad (low) battery or alternator. I think its the battery as it reads a bit low on the multimeter.
Thanks.
Thanks.
Leo
1995 Polar Silver Porsche
Six Speed, ABD, CR1, Has chrome wheels, want to return to "17" light alloy wheels"
Old 01-10-2008, 05:46 PM
By ABS i meant AIRBAG symbol
Sorry, instead of ABS, my post should say Airbag symbol.
Old 01-10-2008, 05:48 PM
Don Plumley's Avatar
Yes, disconnecting the battery overnight will let your ecu reset. Airbags have a 10 year life before they need to be checked - so you might need the Hammer (PST2) to check the sensors? Just a guess.
Don Plumley
M235i
Old 01-11-2008, 09:37 AM
My understanding is that disconnecting the battery overnight will not reset an airbag light. You'll need to reset it with a Hammer or Scantool (ask me how I know).
1995 993 Coupe
Polar Silver - Gray
Old 01-12-2008, 12:30 AM
Diverwes's Avatar
Yes need to have ECU reset. I hade same took to Porsche for $80 they reset codes.
1991 Turbo Polar Silver.
415 HP of pure FUN
Old 01-12-2008, 11:37 AM
bigchillcar's Avatar
tried everything to get my ecu reset by disconnecting for hours and using the bosch hammer. i finally threw in the towel and removed the bulb for the airbag/seatbelt warnings..no idea if i have a working bag or not now..
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 01-13-2008, 07:38 AM
might add my problem was apparently caused by installing a new stereo without first disconnecting the battery..
Old 01-13-2008, 07:39 AM
