fogged clocks
I HAVE carried out a search but without any success honestly...
![]() so my Tacho mists up sometimes which I think means moisture has gotten inside it, is there a fix which doesn't involve pulling it all apart, (it looks pretty well put together)
Nineteen Ninety One 964 |
Member
on older brit cars we used a hair dryer or heat gun to 'bake' the moisture out..........
Paul 91 964 C2 Targa sold (shipped back to the fatherland) 09 Cayman PDK 17 Titan 55 Sunbeam S7 Deluxe 70 Triumph Bonneville |
You can stick them inside a vacuum oven and suck the moisture out. I don't know how to prevent the water vapors from going back in (maybe put a bead of silicone sealant around the back?)
I would flush it with dry nitrogen gas or CO2 or something inert from a gas tank.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Reckon I can safely use a hairdryer without
melting clocks/gassing myself
I would assume that moisture will just change to vapor phase when heated and condense back to moisture when it cools down. Find a way to flush moisture out by displacement method.
How does it enter the gauge initially (generally)
not had the clocks out yet to inspect them so not sure what to look for leak-wise
I don't have foggy gauges. 95k miles.
Canadian Member
I've heard of drilling a small 1/16" hole in the bottom of the face glass; this allows the air inside the cab and inside the instrument glass to be the same temp; eliminating the condensation.
My 74 did it the odd time; but not to often. |
Often wondered about a vent hole, I suppose I could always try it, ans epoxy it up again, should it not work.
