sgoldberg's Avatar
advice on a B&B vs Fabspeed for a 964
I have a 1989 964 C4 and I RUF muffler by-pass pipe whcih sounds very nice. However, I would a more agressive sound and proformance. I see that many 964 owner use B&B and FaBspeed exhaust. Which is better as it relates to overall sound and proformance quality?
Thanks for your help.
SG
Old 12-25-2007, 10:05 AM
i'd pass on the Broken& Busted setup.
206 637 4071
Old 12-25-2007, 10:43 AM
Manny Alban's Avatar
I've had B&B headers/exhaust on my 90 C2 since 1998. The headers have been great. No problems at all. The muffler cracked in 2001, but to the credit of B&B, they worked with me and I ended up with a new muffler that's been perfect since then. No cracks at all. Evidently, that was a problem they were having early on. No affiliation, just a customer.
A friend of mine got the Fabspeed setup. He had some installation problems that required parts to be sent back, but in the end, he got it working fine.
When my car was still a street car, the B&B had a resonance at around 3000 rpm. Went away at 3500 rpm. Wasn't a pain, but you noticed it.
Old 12-25-2007, 10:50 AM
sgoldberg's Avatar
which do you think sounds better? i checked out the Fabspeed site and their stuff sounds good for the 964 but videos are only so good with Sound effects. also do headers make a BIG difference in proformance?
Old 12-25-2007, 10:55 AM
I actually liked the sound of the Fabspeed more than the B&B. I believe Bruce Anderson said in his 911 Performance Handbook that the B&B made a significant horsepower improvement. Of course, that was many years ago, before other manufacturers were in the game. Part of the improvement has to be weight. The factory system for the 964 is quite heavy.
Old 12-25-2007, 01:30 PM
cupcar#12's Avatar
last time i dyno'd the B&B setup (full headers to tip) i got 3 HP
i have not done the Fab kit, nor plan to other than the Cat bypass in the spring.
59 356a Coupe
Old 12-25-2007, 02:13 PM
sgoldberg's Avatar
WOW only 3 HP. I guess the true value is in the weight reduction. which do you think sounds better ?
Old 12-26-2007, 09:58 AM
cupcar#12's Avatar
YMMV though - remember my car uses the RS motor, DME, Chips, Etc.
i am moving to a Cat bypass and modified primary muffler, secondary bypass setup soon - and will dyno that setup back to back with my current setup
(Cat, Primary bypass, secondary muffler)
59 356a Coupe
Old 12-26-2007, 02:02 PM
