-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   high performance clutch assembly (http://forums.pelicanparts.com/porsche-964-993-technical-forum/384015-high-performance-clutch-assembly.html)
tjn 12-25-2007 07:03 PM
Hi guys&gals, I have a TT, (1991 Normally aspirated Carrera 4 converted to a TT, )742 HP on the ground. After approximately 3000 miles the clutch will slip in all 5 gears, it is also VERY stiff, lots of pedal pressure! Does anyone have recommendations regarding a different slave cylinder and clutch assembly that will reduce the pedal pressure and hold the torque/hp? Many thanks for your input. TJN/Vettekiller ;)
Don Plumley 12-26-2007 07:43 AM
I thought S-Car-Go racing in Marin has a high HP clutch solution for the monster motors they make. But a quick check of their website does not list. You might want to call Rob King.
You can also search for user "Poorb0yw" - he installed a Tilton clutch, don't know if he did anything to the hydraulics, but when you see his car, it will be hard to believe he didn't touch it.
