Manassas, VA
lucittm's Avatar
Tachometer Swap?
Hello Friends,
When I purchased my 1991 965 last year, I noticed it had a 993 tachometer that was dated 02/1997 (installed 06/1997). It must have been switched with the original at some point. The PO knew nothing about it. It works and looks great.
I would like to offer this tach, pictured below, for a trade for the correct tach for my car, part number 965-641-322-01. Justification: I would like to keep my car original and also observe the Boost indication in the On-Board Computer (OBC).
My instrument tech at North Hollywood Speedometer (shameless plug, 'cause they do good work) said I should sell the 993 tach on Ebay, then buy the correct 965 tach, and pocket the difference. I would rather offer it here.
(965 track car owners with an aftermarket boost guage - here is a newer (maybe more accurate) tach for you, cause the motor gears do wear out. This one has never seen more that 6000 RPM. OK, maybe once or twice.
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 01-02-2008, 10:55 AM
