Sports Purpose 911 Driver
mjshira's Avatar
fuel pressure testor
I need to get a kit to test fuel pressure for my 964. Can anyone tell me which one is best? Locally we don't have anything and I can't find it on Pelican.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-23-2008, 06:34 PM
DW SD's Avatar
i bought some nice pressure test gauges from mcmaster.com . you can get one that is compatible with fuel. Mine has a large face ~3.5" to 4" for more gradients. 0 to 100psi. I used adaptors to fit an oil pressure test port on my engine. I *know* you can do the same. Mine is built with AN - 8 line, but I had that laying around. If you have a good AN shop near you, you can find the thread size for the test port on the fuel rail.
MAC or snap on kits could likely be found on ebay. just make sure they have metric fittings.
Doug
1971 RSR - interpretation
Old 01-24-2008, 04:41 PM
