Remote locks for a 93?
Has anyone added remote key locks to their older 911? Seems like it shouldn't be too hard to do.
Old 02-07-2008, 11:20 AM
simon.marsh@xtr's Avatar
I did it to my 1986 3.2 when I fitted a very flash security system, problem was it had the remote separate from the key. I would like to do the remote with my 964 but I'd like it to be built into the key.
In fact I wouldnt mind updating to keyless entry and a starting button. There must be clever electronic techos that know how to do this.
Cheers
Simon "Swampy" Marsh
1986 3.2 Carrera Coupe black and beautiful
1991 3.6 964 Coupe Guards Red
1992 3.6 964 Coupe Turbo Look widebody.
2004 3.6 996 Turbo
Old 02-08-2008, 12:16 AM
I installed the DEI Valet 712T keyless system on my '91 a couple of years ago and it has been the most useful mod I have done to my car.
Available at Circuit City for $59.99 If you get it, e-mail me for the instructions for the no-frills set up instructions just to lock and unlock the doors on your 964. Works great and doesn't interfere with the sensitive alarm system.
Old 02-10-2008, 12:27 AM
How large is the remote on the 712T? Sounds like the way to go. How did installation go?
Old 02-21-2008, 04:26 PM
+1 on this topic glad someone brought it up
Old 02-22-2008, 06:26 AM
The remotes (2 are supplied in the system) are very compact, with only 4 butttons. I just use the open and close ones. Installation is not difficult. The passenger seat has to be romoved to access the alarm system where you tap in the remote wires and locate the smal control box. Here are the instructions. Good luck.
How to Install Keyless Entry (DEI Valet 712T) in a 1991 Porsche 964
This is for a “no-frills” set-up to lock and unlock the door only – no lights, horns or other functions.
1. Remove passenger (right) side seat.
2. Locate the factory alarm. It’s the box closest to the central tunnel.
3. Split open factory firing harness (should have the YELLOW connector). Be careful not to cut any wires.
4. Locate the following wires in factory alarm harness:
Brown/Blue - LOCK (-)
Brown/Green - UNLOCK (-)
Each of those wires should be triggered by a - (negative/ground) input. Meaning, if a (-) input is given to one of those wires they will activate. This can be tested by using a wire tester. Connect tester to a ground (you should see a bunch of brown wires bolted to one of the grounding points - you can use this) on the other side tap wire. This should lock or unlock the doors, depending on which wire you tap.
5. After identifying the correct wires, tap (place inline) the related output wires of the DEI Valet 712T. See the table below for the connections.
6. Next, connect 12v constant and the ground wires.
- I used the 12v constant going to the factory amp. Red wire...PLEASE use a cable tester/multimeter to verify this.
- Ground used the same grounding point as the others.
712T Harness Car Connection
H1/1 Red - (+) 12V constant power input (Use multimeter!)
H1/5 Green/black - Brown/Blue - LOCK (-) *inline tap
H1/7 Violet/black - Ground
H1/8 Blue/black - Brown/Green - UNLOCK (-) *inline tap
H1/9 Violet - Ground
H1/11 Black - Ground
I cut these wires to the required lengths before connecting them. The unused 712T wires I clipped off a couple of inches from the connector to the Valet, which I secured to the tray underneath the right seat. Test all operations, including the alarm, before re-installing the seat.
Old 02-22-2008, 07:08 AM
Don Plumley's Avatar
Thanks for the Post - very helpful!
Don Plumley
M235i
Old 02-22-2008, 08:18 AM
This looks extremely helpful. One last question that I am puzzling over. Isn't there some type of electro-mechanical device required to lock/unlock the doors and wouldn't this have to be installed in the door? I'm trying to visualize getting rid of "turning the key in the door" replacement.
Old 03-07-2008, 01:34 PM
The 964 has an electrical central locking system, so locking or unlocking one door operates the other as well. The master button on the console synchronizes the door locks from the inside, although I've never found a meaningful use for this feature. Anyway, the answer to your question is that there are solenoids at each door locking button that are actuated either by key operation or a trigger signal from the remote control box. My system has worked flawlessly for three years of daily operation.
Here is a photo of the fob to give you a idea of its size:
Old 03-07-2008, 08:45 PM
Many thanks to Hambisa for some excellent directions that were *exactly* what was needed to hook up the door lock/unlock. Now, does anyone know how to hook up the panic button for the horn? I'll start a new post for that one.
Ride on!
Old 05-13-2008, 06:52 AM
JC Whitney also has some inexpensive add-on keyless entry systems that just trigger the factory locks/alarm system, I used one of these on my 993 and it works perfectly. I do not remember the exact model I used, but there are several threads over on Rennlist in the 993 section regarding which unit to buy and how to install.
http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=keyless+entry
Old 05-13-2008, 08:13 AM
P-Zero Burner
911Urge's Avatar
These are great instructions but for those with an 89-90 964 your hook up will be different. Instead you will hook into the Central Lock Control unit that resides at the top of the passenger footwell under the dash. Its a small black box that is supported by a small bracket. Dont bother with the factory alarm which is nearly inaccessable and a PITA to hook into.
Use the same wiring as listed above at the Central Lock Control unit and you are good to go.
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 01-10-2009, 07:37 PM
I just installed my 712t and it was super fast and super easy, i think it took me about an hour and it works just fine plus i got it at Circuit city with 40% off since they are going out of business and ended up paying $36 its quite a deal.
94 Carrera 2
99 Carrera 2
93 Corrado SLC supercharged
86 Kawasaki LTD 454
Old 02-04-2009, 05:01 PM
