Momo Wheel on a 964
when you mount a momo wheel on a 964 how do you eliminate the airbag light from coming on ?
2006 Cayman S 93 RS America white(now living in Arizona) 1974 911S/CARRERA (now living in Australia) Livermore Ca. |
There is a factory part from Porsche #928.612.220.00 But it is spendy.
You can just put in a resistor, 2.8-2.9 ohm 1/4 watt, into the plug you disconnect from the airbag. This fools the system to thinking an airbag is in place. Caution 1: Disconnect they battery for at least 30 minutes before doing this. Overnight better. Caution 2: Don't turn the key on with the airbag disconnected or you will likely trip the light. Note 1: You may still need the Bosch Hammer (or equiv) to extinguish the light.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
There is a jumper that gets installed. I may have mine in the junk pile of ripping out all the wiriing or it may have already been trashed. There were a couple threads on the 964 board on Rennlist about 2 years ago that had pictures and the part number for the jumper...
edit: (Don types faster I guess) I did not need anything to reset the light. The part was about $30 IIRC. It disables both air bags (as mine were both removed, it was moot).
Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) |
thanks guys I will look for the part number on Rennlist
I removed the light bulb from the gauge.
--Dave 1993 911 C2 Coupe 2014 Dodge Ram 1500 Ecodiesel |
You sound like an "X" VW guy... I like
