1992 vs 1990 speedo, a good one.....
My car is a 1990 W/ all of the abs components removed from the car.
It is possible to fit a 1990 speedo sensor on a 1992-1994 transmission?
If yes, how?
Is the machined hole (for the sensor) there on a 1992-94 gearbox housing?
Is there a disk with magnets (for signal) in the 1992 box that is missing?
Thanks.
1990 964 C4 Targa, 1970 VW Bug Hot Rod
2009 US made Buell XB12Ss, 2015 Suzuki DR650SE
2012 Arctic Cat XF1100 turbo (over+220hp)
2004 RARE Ski-Doo Elite 1500 SXS snowmobile
2016 brand new kid
Old 01-30-2009, 06:21 AM
I believe it is possible my Cup car is 1990 with a 1991 box. Te speedo does not work.
My mechanic tells me the box needs a toothed wheel added into the LSD to give the speed reading. The sensor pics up the speed signal from wheel.
I don't have the list of parts yet. I think you can use the later casing and fit the parts.
Good luck
1990 Cup
1991 RS
1994 CS
Old 01-31-2009, 01:54 PM
