oil in my intake
Hi,
I have oil in my intake, I took the intake out. what is the cause usually in this situation. I need assistance, waiting for a reply ASAP.
George
Old 03-19-2008, 06:47 PM
kurquhart's Avatar
Originally Posted by dinopipes View Post
Hi,
George
Overfilling is one possible cause. Have you changed or topped off the oil recently?
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 03-19-2008, 07:46 PM
oil in my intake
how would the oil get there. from the that thermostat.I always checked the level it was always between the lines at idle and normal temp.I use 20 w 50 synth.My porsche is a 1992 964.>before i put the intake on,can someone give me a reason ,please.
Old 03-20-2008, 07:20 AM
colo964's Avatar
There is a breather hose on the top-rear of the tank and vacuum in the intake manifold. A small burp or splash in the tank/thermostat area or even a hard turn can cause a slurp of oil to get in the intake. Even hot oil mist may be vac'd up and condense in the manifold. I have always had some oil in mine, only once was it enough to make oil smoke in the tail pipe. Even then it wasn't enough to foul the plugs
You now know how easy it is to open the manifold, just sop up the oil if it is a problem - 99.98% (1 day in 4200 days of operator-ship) of the time it has not been for me.
Old 03-20-2008, 09:45 AM
colo964 is dead on - same happened to me. Most likely cause is oil overfill though - you could have had oil there for a while. Make sure you also clean the ICV and the air flow meter. Especially the air flow meter does not like oil contamination.
Just out of curiosity, how long did it take you to remove the intake manifold? Anything to watch out for?
Happy spring cleaning
'91 C2 Targa
Old 03-21-2008, 07:28 AM
