Cam Timing 964? range?
the only specs I can get for cam timing on the 964 is 1.26mm. But I cannot believe that there isnt a range like 1.25mm-1.35mm or something of that nature. I recently replaced the cams in my 3.0 SC with 964 cams and the best I could do after much sweating was left side @ 1.31mm and right side @ 1.30mm. So my ever thinking mind wants to know, what are the specs on range if any. pros and cons etc.
anyone? anyone? Bueler?? thanks Chris |
Thanks bill, I guess I am good at the current settings of 1.3 + 1.31 eh? if I am reading that correctly
Cheers Chris Now back to our regularly scheduled programming...................................... |
Chris,
I'm looking at the same route. Is everything up and going and what if any do you notice? Cheers |
| All times are GMT -8. The time now is 09:30 PM. |
