-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964: bump steer correction (http://forums.pelicanparts.com/porsche-964-993-technical-forum/398889-964-bump-steer-correction.html)
kurquhart 04-09-2008 12:48 PM
I just spoke to Steve W. at Rennsport Systems, and he feels that the lower strut bolt must be changed to 14mm for safety reasons, so I will get that taken care of before my next track event.
We also discussed the rubber isolation in the 993 inner tie-rod and I came to the conclusion that Evo tie-rods are the answer, so I ordered a set of those from Steve since he had them in stock. After all the money, time, and effort I have spent so far it seemed a shame not to go ahead finish up the front end properly. I will post photos when I get them.
Thanks for everyone's help and advice so far.
911nut 04-11-2008 04:46 PM
Cost?
kurquhart 04-11-2008 07:13 PM
Originally Posted by 911nut (Post 3881468)
Cost?
$5k in parts alone. What's the saying about racing Porsches: as addictive as crack and twice as expensive?
kurquhart 04-11-2008 09:55 PM
GT2/Evo tie rods:
http://www.kurquhart.net/photos/Pors...r/IMG_0398.JPG
911nut 04-12-2008 04:49 AM
Kris, why so much?
I thought it was $5k if the 993 struts were used.
The Evo uprights list for $700 each, correct?
Other than tie rods and wheel bearings what am I missing?
kurquhart 04-12-2008 07:55 AM
Originally Posted by 911nut (Post 3882104)
Kris, why so much?
brake rotors/hats
front control arm monoballs
993 ball joints (we missed this one originally, too)
adjustable drop link (optional)
kurquhart 04-22-2008 09:26 AM
Originally Posted by kurquhart (Post 3866082)
One side is 964 RS, other is a ordinary heim joint (red in first pic above).
My apologies for the misinformation: the red drop link is from Tarett Engineering:
http://www.tarett.com/items/993-964-products/964-993-c2-front-drop-link-993fdlnk-detail.htm
Ag02M5 05-17-2008 05:17 PM
Hey guys.
Quick question.
For my widebody, the front suspension is mostly identical to a narrow body 964 except for the upright. I am assuming this pushes the wheel out a little bit more for the wide body.
Do you have any idea how the EVO uprights compare as far as where the wheel will sit in the fender. Is it more like the 964 or the 965?
Thanks.
RT
Bill Verburg 05-17-2008 07:14 PM
RT
The difference in front track on a 964 vs 964t comes from mounting the suspension in the outer holes rather that the inner. You can swap from one config to the other in an hour or so.
as to uprights
all 964 are steel, all 993 are aluminum
964 has axial mount brake ears all the others have radial mount bosses
964 & 964t use a slightly different rotor o/s from 993
the 993RS uright raises the outer end of the steering arm so that it is more horizontal at static ride height on a lowered car. You can lower the car further w/ 993RS uprights than w/ any of the others
here are 964 & 993RS(akaEvo) uprights
http://forums.pelicanparts.com/uploa...1211076547.jpg
here is a pair of 964t uprights
http://forums.pelicanparts.com/uploa...1211076608.jpg
kurquhart 05-22-2008 06:03 PM
I think I finally have the front end done: replaced lower strut bolt with 14mm and swapped inner tie rods for Evo part.
http://forums.pelicanparts.com/uploa...1211504586.jpg
Don Plumley 05-22-2008 08:04 PM
Wealth of knowledge here - thanks for sharing guys!
Ag02M5 07-11-2009 08:27 PM
Originally Posted by kurquhart (Post 3882271)
brake rotors/hats
Did you try to install on the 964 ball joints?
I am guessing they are a must replace item?
Thanks.
RT
kurquhart 07-12-2009 08:17 AM
Thanks.
RT
It was required on my car, but I have read other posts that don't mention it. I have a very early C2 (built 12/89), and I am continually finding differences with the later cars.
