 the big advantage is the hot wire MAF sensor over the 964 barndoor MAF sensor yes you could rewire the pin outs and connections of the 964 harness not sure how the MAF plugs differ Here is a pin out map showing the '94-95 non vram and '96-98 RoW vram http://forums.pelicanparts.com/uploa...1424904188.jpg there are only 2 differences between non vram and vram pin1 & pin 32 on US cars pin 2 & pin 54 are connected on RoW they are left open this just affects the stock maps and the central informer messages you also nee a chip change the chip for vram activates pin1 & 32 differently all in all it's a lot easier to use a 993 harness, there is only 1 55pin version it has all the connections for both vram and non vram you just choose the ones you are using I mapped some of the tip pin outs but they didn't particularly concern me  |
 So I just need to buy 2X14mm bolts & I'm off to the races?  Sounds too easy!
 Hello
	I have owned a 930 for years and become a custom to adjusting AFR's and keeping her running at its best, In the past I have owned a 88 Carrera and Very simple to work on also. I just bought a 97 993 OBDII car, there seems to have alot going on in the engine compartment, Should of i stayed with a OBDI car ? It looks like a steep learning curve , Any tips on what to look for that can go bad? Wiring , vacuum connections and so on ?  |
 The biggest issue is SAI which tends to get clogged ports as mileage accrues, The OBD2 system then throws a CEL,which you can safely ignore until it's time for state inspection where the CEL code will cause the car to fail to pass. You can read all about SAI in another sticky. next on the list of possible issues is chiping the car for performance gains, If you want to do that it will be more expensive and must be done by a competent shop, Steve Weiner @ Rennsport Systems can help in this area.  |
 964 front bumper
 This is the auxiliary(second) oil cooler kit used on 993 Cup and RSR, it also fits all 964 models
	This one is sandwiched w/ the AC condenser on the left side of the car http://forums.pelicanparts.com/uploa...1498414625.jpg http://forums.pelicanparts.com/uploa...1498414625.jpg Stock lines http://forums.pelicanparts.com/uploa...1498414625.jpg W/ secondary lines installed http://forums.pelicanparts.com/uploa...1498414625.jpg lines run down and across the front http://forums.pelicanparts.com/uploa...1498414625.jpg second cooler sanwiched betweeen AC condenser and stock fan http://forums.pelicanparts.com/uploa...1498414625.jpg final connections http://forums.pelicanparts.com/uploa...1498414625.jpg Alternatively a stock cooler can be installed on the left but plumbing is more difficult These are stock coolers, the I/O ports on top make the installation more difficult toi plumb http://forums.pelicanparts.com/uploa...1498415124.jpg http://forums.pelicanparts.com/uploa...1498415124.jpg  |
 Air cooled aero summary
	http://forums.pelicanparts.com/uploa...1498920237.gif  |
 I have Polished Aluminum wheels,17". whas that a stock item?
 http://forums.pelicanparts.com/uploa...1521065316.jpg http://forums.pelicanparts.com/uploa...1521065316.jpg  |
 I think you mean Cup II's but we know what you meant.
 Bill
	Not having the time to read all this, I bought the 993 C2, because I have the Carrera and SC. Meaning I have the true 911, but the 964 looks like a 911 body, but under is major changes over the 911. The coil over shocks I never liked, but needed a new model for AC that works, so the 993. I would love to add a 964 C2 but prices are stupid thanks to Singer. I do see the exhaust and rear end a better improvement with the 993 over the 964, but both models seem so complex compared to my SC and not crazy about the PS system.  |
 Here is a stock 993vram dyno tested (dotted lines) on a mustang dyno vs a 964 (solid) with a chip. Sorry for the poor picture but it makes the point. Is the 993 faster? maybe but not noticeably. The peeks from the vram are what give that feeling. Well modified both are great cars. They all have their quirks. http://forums.pelicanparts.com/uploa...1540295543.JPG  |
 Here are some that I've seen http://forums.pelicanparts.com/uploa...1540336549.gif Gearing and tires have a big influence too, the 964 /03 is particularly nice in 3rd Any car can be made raw, I have a heavily modded '76 911 and a heavily modded '95 993, the 993 is much more direct and brutal. Both are a ball to drive.  |
 Just added a 964 that I had years ago, it was hampered by ssi headers, but down only ~10 lb-ft peak.  All are rear wheel torque in lb-ft
	http://forums.pelicanparts.com/uploa...1540339861.gif  |
 Mustang or dynojet?
| All times are GMT -8. The time now is 04:50 PM. |
