LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Bill Verburg's Avatar
Originally Posted by drb930 View Post
So just to be clear if I wanted to run a 95 993 OBD-1 55-pin DME on 94 964-
1) It would require a complete pinout change of the original DME harness.
2) Or use the 95 993 OBD-1 harness and DME.
Varoram requiring 2-wires change on the 95 993 OBD-1 DME???
How much better is the 55-pin 95 993 OBD-1 DME? and what is to be gained from running it?
Also what are the differences and are there any gains to be had from the 94 964 Tiptronic Computer to the 993 Tiptronic computer???
I'm not afraid of wiring, but I don't understand all the hardware differences...Thanks for your input guys!!!
The 993 uses Motronic 2.10.1 which is an updated version of the 964 unit
the big advantage is the hot wire MAF sensor over the 964 barndoor MAF sensor
yes you could rewire the pin outs and connections of the 964 harness not sure how the MAF plugs differ
Here is a pin out map showing the '94-95 non vram and '96-98 RoW vram
there are only 2 differences between non vram and vram pin1 & pin 32
on US cars pin 2 & pin 54 are connected on RoW they are left open this just affects the stock maps and the central informer messages you also nee a chip change the chip for vram activates pin1 & 32 differently
all in all it's a lot easier to use a 993 harness, there is only 1 55pin version it has all the connections for both vram and non vram you just choose the ones you are using
I mapped some of the tip pin outs but they didn't particularly concern me
Bill Verburg
Old 02-25-2015, 01:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
Originally Posted by FredC View Post
Hi guys, quick question: I have a '91 964C4, can I simply swap in 993 stock 993 front shocks or do I need to make modifications to the 993 shocks? thanks! Fred C.
The 993 struts use a 14mm and a 12mm bolt to connect the wheel carrier the 964 use 2x 12mm bolts this would have to be addressed
Bill Verburg
Old 02-25-2015, 01:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
So I just need to buy 2X14mm bolts & I'm off to the races? Sounds too easy!
Old 02-28-2015, 06:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Cobalt's Avatar
The same goes for the 94 turbo. It uses the 14mm and 12mm bolts.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 02-28-2015, 02:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Hello
I have owned a 930 for years and become a custom to adjusting AFR's and keeping her running at its best, In the past I have owned a 88 Carrera and Very simple to work on also.
I just bought a 97 993 OBDII car, there seems to have alot going on in the engine compartment, Should of i stayed with a OBDI car ? It looks like a steep learning curve , Any tips on what to look for that can go bad? Wiring , vacuum connections and so on ?
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 04-19-2015, 05:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Originally Posted by heliolps2 View Post
Hello
There is no doubt that OBD1 is easier to deal w/ but it's a bit late for you to do much about it.
The biggest issue is SAI which tends to get clogged ports as mileage accrues, The OBD2 system then throws a CEL,which you can safely ignore until it's time for state inspection where the CEL code will cause the car to fail to pass. You can read all about SAI in another sticky.
next on the list of possible issues is chiping the car for performance gains, If you want to do that it will be more expensive and must be done by a competent shop, Steve Weiner @ Rennsport Systems can help in this area.
Bill Verburg
Old 04-20-2015, 01:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Alex973's Avatar
964 front bumper
"IGNITION LEFT OF STEERING"
Alex
Old 09-22-2015, 05:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
This is the auxiliary(second) oil cooler kit used on 993 Cup and RSR, it also fits all 964 models
This one is sandwiched w/ the AC condenser on the left side of the car
Stock lines
W/ secondary lines installed
lines run down and across the front
second cooler sanwiched betweeen AC condenser and stock fan
final connections
Alternatively a stock cooler can be installed on the left but plumbing is more difficult
These are stock coolers, the I/O ports on top make the installation more difficult toi plumb
Bill Verburg
Old 06-25-2017, 10:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
Air cooled aero summary
Bill Verburg
Old 07-01-2017, 06:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
I have Polished Aluminum wheels,17". whas that a stock item?
Old 02-24-2018, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
No, the most common 993 wheel is the cup 2, 7x17 & 9x17
Bill Verburg
Old 03-14-2018, 02:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
Cobalt's Avatar
I think you mean Cup II's but we know what you meant.
Old 03-15-2018, 10:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
wgwollet's Avatar
Bill
Not having the time to read all this, I bought the 993 C2, because I have the Carrera and SC. Meaning I have the true 911, but the 964 looks like a 911 body, but under is major changes over the 911.
The coil over shocks I never liked, but needed a new model for AC that works, so the 993.
I would love to add a 964 C2 but prices are stupid thanks to Singer.
I do see the exhaust and rear end a better improvement with the 993 over the 964, but both models seem so complex compared to my SC and not crazy about the PS system.
Old 04-28-2018, 08:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
Originally Posted by wgwollet View Post
Bill
Let me tell you something. I owned a 964. I bought it back in 2011, when they were cheaper than a new Honda Accord. I bought it because I could not afford a 993 at the time. I was never impressed with it, both stylistically and performance wise. It looked heavy, felt slow and never put a smile on my face like my future 997 and current 993 does. If you want a visceral feeling 911, buy an SC or 3.2. Because the 964 is more closely akin to the 993 than the torsion bar suspension cars. I absolutely love my 993. It is so much faster than my old 964, and still has the aircooled feel. It is also so much better looking, and absolutely blows the 964's performance.
Old 10-22-2018, 08:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
Cobalt's Avatar
You must have had a rather poor 964. I have had them and driven them all. They are all good but I would never trade my 964 for a 993 or go back to torsion bar cars. To each their own. Your 993 might feel much faster but in actuality they are rather close.
Here is a stock 993vram dyno tested (dotted lines) on a mustang dyno vs a 964 (solid) with a chip. Sorry for the poor picture but it makes the point. Is the 993 faster? maybe but not noticeably. The peeks from the vram are what give that feeling. Well modified both are great cars.
They all have their quirks.
Old 10-23-2018, 03:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
The torque curve for the vram looks awfully anemic
Here are some that I've seen
Gearing and tires have a big influence too, the 964 /03 is particularly nice in 3rd
Any car can be made raw, I have a heavily modded '76 911 and a heavily modded '95 993, the 993 is much more direct and brutal. Both are a ball to drive.
Bill Verburg
Old 10-23-2018, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
Just added a 964 that I had years ago, it was hampered by ssi headers, but down only ~10 lb-ft peak. All are rear wheel torque in lb-ft
Bill Verburg
Old 10-23-2018, 04:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
Cobalt's Avatar
Mustang or dynojet?
Old 10-23-2018, 07:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
Mustang or dynojet?
All were done on one of 3 Dyna-Pack chassis dynos
Bill Verburg
Old 10-24-2018, 05:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
Cobalt's Avatar
I have found the mustang isn't as kind as the dyna-pack's or dynojets.
Old 10-24-2018, 02:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
