LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Bill Verburg's Avatar
Factory Alignment specs
993 measuring points
964 measuring points
Bill Verburg
Old 04-01-2009, 09:23 AM
Here's some info on what the factory thought was good for a 993 race car, in this case a '97 GT2 Evo
Bill Verburg
Old 04-10-2009, 04:31 AM
964RS shock mount
993RS shock mount
993RS suspension
993GT2EVO/RSR suspension
Bill Verburg
Old 04-20-2009, 03:58 AM
120 HP/Liter is all I ask
Bill- Are the 993 RS front struts of the monotube or dual tube design? I can't tell with the rubber boots on the strut.
Old 04-20-2009, 07:30 AM
The RS are monotube Bilstein
Have you got any pics of the 964Cup or RS strut tops?
Bill Verburg
Old 04-20-2009, 07:53 AM
Sure, here are some pictures of the 964 RS and Cup parts. I will take some pictures of 964 RSR front and the 964 Cup rears when I can get them out of storage around here.
Below are the front and rear 964 RS suspension mounts:
Below are the 964 RS (left) and 964 Cup (right) front suspension tops. The Cup part mounts the pivot point more toward the center of car for more negative camber.
964 RS front strut mount disassembled:
Rear RS shock mount disassembled (964 RSR is same, but with a hollow cap nut):
Front strut rod of 964 RS showing smaller, Bilstein dual tube shock design rod:
Front strut rod of 964 Cup showing the larger, Bilstein monotube shock design rod:
Old 04-20-2009, 09:40 AM
That's great, Thanks!
Here's a brand new out of the box 993RS set
Bill Verburg
Old 04-20-2009, 01:22 PM
As promised, the rest of the 964 racing mounts, it took me a while to find the stuff. Here goes:
Below is an unassembled 964 Cup rear shock mount. The parts for the monoball are laid out left to right as they go top to bottom; I show the spring perch here for clarity since the small washer goes under it. The two tubular pieces on each side of the monoball telescope together within the monoball. The circlip is to retain the monoball into the plate and the studs are pressed into the plate.
Below is a 964 RSR front shock mount. Note similarity to 993 RS mount Bill shows above which is a sealed version of the RSR below.
Old 05-01-2009, 03:02 PM
Thanks!
So the Modes are copies of the RSR's
Here is a Mode that I just installed on my 993
and the original JIC
Bill Verburg
Old 05-02-2009, 05:39 AM
Modes are a very good copy too, here is underside of 964 RSR Front. Although it looks like Porsche used the same casting for the center as the rear mount (shown here below), the number on the casting is different.
Here is RSR rear which is same as RS but with hollow top nut.
Old 05-02-2009, 06:57 AM
SAM DACOSTA's Avatar
An excellent read and comparison between the Porsche 964 and 993 models. I own a 964 and definitely made the right choice based on your data (I wouldn't reveal otherwise... ).
I've attached a picture of my 1990 Porsche Carrera 2 Cabriolet.
SAM DACOSTA
1990 Porsche 911 Cabriolet (964)
2000 Porsche Boxster (986)
2002 Porsche 911 C4S (996)
Old 07-02-2009, 02:31 PM
jake61
Bill, I just did a 3.6 (95 993)motor conversion in my 78 SC.I am finding the need for more oil cooling was wondering if you have any suggestions on any particular type of coolers,mounting locations etc. Thanks in advance John Szabo
Old 08-03-2009, 03:59 PM
For street use I've been happy w/ B&B #153202 5.5"x2.25"x20"
for track use the bigger #153201 6"x3"x24" is better.
For additional cooling(only needed for hot track use) plumb the above in line w/ a late Carrera radiator cooler in the fender.
The B&B valance mounts above do require a valance w/ center intake
Bill Verburg
Old 08-04-2009, 03:53 PM
All manual transmissions used in series production, w/ afew customms thrown in
Bill Verburg
Old 08-29-2009, 04:26 PM
993RS front drop link ctr, aftermarket links w/ monoballs flanking
front 993RS drop link top, rear 993RS droplink bottom
f/r 993Rs sways and mounts(look for the green dot on rubber parts for RS )
On the back you need the curve RS drops on a lowered car, but even on the front the curved ones add to clearance around the strut & brake lines.
in back you only need curved at the extreme hard setting
Bill Verburg
Old 10-12-2009, 02:01 PM
added a few more wheels, 10" ET65 w/ 265/35x18 is a known good fit at any ride height. 10 ET56 on my car kisses the drivers side lip at full compression(the car is at an extremely low height)
Bill Verburg
Old 12-29-2009, 08:43 AM
Bill Verburg
Old 01-13-2010, 06:00 AM
Stock 993 RS/cup brace
Bill Verburg
Old 03-05-2010, 02:29 PM
Bill- I have noted the cast alloy brackets used on 964 RS cars with the big gas tank option, have you noted the same?
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 03-06-2010, 09:26 AM
Here are the ones I've seen besides the one on the red 993 Cup car above
993GT2 w/ black(appear to be steel) risers
'90 964 Cup
'91 964 cup
'92 964 Cup
Andy Jenks old Cup
'90 RS/lw
964 Cup yr unknown
964 Cup yr unknown(it had the mg wheels though)
RoW Rs yr unk.
Bill Verburg
Old 03-08-2010, 08:08 AM
