Help with X4/1 Connectors
Hello. I purchased a salvage 1996 993 that I plan to use to rebuild a 1977 930 (please don't judge me). I've owned Porsches since 1999 but am new to working on them.
I am was in the process of some disassembly to get the 993 running and wanted to remove the support for the control units under the driver's seat to free up the harnesses. I got the bright ideas to remove the female side of the X4/1 connector by prying it from the base. The wires all dropped out.
I tried to replace them according to the wiring diagram, but some of the colors did not match the diagram.
I (carefully) removed the base from the male side to see it's wiring and found that some if the colors also did not match.
I provided diagrams of how I wired the female side of the connector but am not sure if it is correct. I have not yet traced every wire through the diagrams to make sure. Those I have in red are the mismatches.
Does anyone know what how the female side of the X4/1 connector is supposed to be pinned?
Thank you for any help or confirmation on my wiring.
Old 01-19-2025, 04:55 PM
Tags
pinout diagram , x4/1
