1971 911T's Avatar
early 1990s C2
should i jump at the opportunity of getting one?
how much to offer for one in running condition, under 100k miles, and good bodywork ?
what are the more specific C2 Tiptronic things to be careful of?
thanks
ps. C2 tip or C4 manual ? ? ?
Old 04-30-2008, 11:43 AM
Kevin70914's Avatar
I have seen several C2 90-91 5spd with less then 100K mile for
$15-20K. Buy what you like...
Cheers
Cheers,
Kevin
02 Boxster S Green "Hulkster" Track Car
01 Boxster S
87 Carrera
Old 04-30-2008, 03:44 PM
Don Plumley's Avatar
Early 90's common issues (get a real PPI):
- Cylinder head seal: Either fixed, leaking or good.
- Failing dual mass flywheel (DMF): If clutch replaced, likely replaced. Look for records
- Make sure the distributor belt has been replaced and has the vent kit installed
- Tip: Again, that's a PPI issue. If fluids changed, should be okay.
Don Plumley
M235i
Old 04-30-2008, 05:45 PM
Agent Orange
ilko's Avatar
They can be very solid cars, but as Dan said, a PPI is very important. Use a PCA, Pelican, or Rennlist recommended shop to do the PPI.
Old 05-01-2008, 10:51 AM
