-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Trunk Hood will not open! (http://forums.pelicanparts.com/porsche-964-993-technical-forum/408118-trunk-hood-will-not-open.html)
Bad Bob 05-07-2008 05:06 PM
Emergency release cable broke off as well and came out in my hand! Now What?
Don Plumley 05-07-2008 05:50 PM
IF it is installed, it's behind the left front wheel fender liner, at least that's where mine is.
Have someone press down on your hood as you pull the release cable.
Bad Bob 05-07-2008 10:48 PM
Hood Latch issues
Thanks, I'll tear the thing apart and have a look!
I tried the hold the hood down trick, the release lever is loose as there is no tension on the cable. Something seems to have come loose at the latch end.
Bad Bob 05-07-2008 10:50 PM
Wine Country California!
I see you live in wine country California! Cool, I live in wine country British Columbia!
StanAE86 05-11-2008 09:54 PM
Should be the same as here:
http://www.rsamerica.net/articles/tech/keithv_front_hood_release_article.htm
Bad Bob 05-27-2008 09:46 PM
Big Trouble, The emergency release cable has broke off as well ns pulled out in my hand!
Now What? Any Ideas? "HELP"
dypascal 05-29-2008 09:51 AM
If you Know where to borrow one boroscope,you can try with a hook.it's tricky but it's work.Goo luck.
Pascal
