My knees hit steering wheel - 964
I'm not all that tall (6 ft) but most of my height is in my legs. The problem is, if I adjust the seat so I'm comfortable with the clutch, i.e., not tip toeing it, my left knee sometimes hits the steering wheel when I release the clutch.
Also my hands can hit my knees when I turn without shuffling. These interferences can get very distracting when things get busy. Do others have this problem?? Is there a remedy?? I was thinking a 2" spacer to bring wheel closer to me would do the trick. Ever hear of such a thing?? Thanks for help, Dan |
Personally, I'm short, so I have the opposite problem.
Yes, steering wheel spacers for aftermarket wheels do exist. That's a complaint of the Momo mounting kit that with a dished wheel make it too close. I'm not aware of a spacer for the factory airbag wheel, but perhaps someone knows better. Have you moved the seat down?
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Do you have the stock seats, or buckets?
I'm 6'2" and I fitted a Sparco bucket in mine the other day which gives me the exact same problem you described. I have never had this problem with the factory eletric seats though as they were extremely adjustable. The solution that I am going to use is to remove the original seat mounting points for the electric seats, which are welded to the floor pan and use a smaller diameter steering wheel. A spacer was a factory option (can't remember the code off the top of my head), and you can trying fitting a Momo Prototipo replica. Momo makes several types (i.e., different dish depths) so I am sure you'll be able to find one to suit your needs. Good luck! |
Thanks for your replies.
I have the electric seats and have tried all kinds of positions. I've concluded that moving the steering wheel is the best option, so I'll take a look at Momo wheels. Dan |
In case you want to take the OEM route, the option code for the "Sport steering wheel with elevated hub" is 018. I got this number off the options sticker under the hood of a 965.
Obviously the Momo route will be the cheaper one
You can also get a smaller wheel. The stock wheel is 350 mm diameter. Momo makes smaller diameter wheels. In a 964 or 993 - cars with power steering - it will not be an issue. In an older car, it would take even more strength to turn the wheel. If you switch to a Momo wheel, you will require a hub adapter and as pointed out, that will move the wheel closer too.
Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) |
Tom W - The OEM wheel in the 964s is 350mm? Keen to know because mine feels gi-normous, and I've never measured it.
dlpalumbo - This is one of the options I'm mulling over: ![]() It's fitted to the 997 GT3 RSR Cup Car!
Thanks RoadSleeper.
Just measured the stock wheel and its 15", 380 mm, so the Momo at 350 mm is just over an inch less in diameter. That plus a spacer might do the trick. |
I am 6 ft and have non power seats. Dont seem to have this problem
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
dlpalumbo - That should work, it's the same setup my friend has in his 2.7 RS clone. While I can't speak for the feel on long drives, I'm sure it'll feel similar to the stock wheel since it's only an inch smaller.
Knees and steering wheel
This post got me to thinking as I drove my 993 this week. The pedals are really offset to the right, different than any car I've driven or am familiar with. Having owned the car only a year and 12k miles, here's a couple of thoughts: the pedal cluster is really set for a more flexation of the ankle to get the sole of the foot squarely on the pedal at full extension.
I experimented with this and my knee doesn't contact the wheel, but when using a full leg motion to shift it does. I find that I splay my knee outwards to avoid bumping the wheel. Learning about the Porsche is an experience.
1995 Polar Silver Porsche Six Speed, ABD, CR1, Has chrome wheels, want to return to "17" light alloy wheels" |
