180mph's Avatar
Send a message via AIM to 180mph Send a message via Yahoo to 180mph
964 warning light for breaks, transveral and engine light all at once?
whats a girl to do. This started gradually with the brakes, then the tranversal light now the check engine. the car is running fine but suddenly having some issues. anyone know what it is before I drive over to the shop? Is this life threatening?
Old 05-29-2008, 02:04 PM
Newsboy's Avatar
There are many things which can cause your warning lights to go on, allot of which are not at all related to the particular thing they are warning you of. Mostly, the cars are very sensitive to stray electrical. Could be a bad plug wire, bad battery or tranmission ground, or ignition coils. It's a process of elimination. Search the site under"Christmas Tree Effect", and you will see allot of information. Also try Rennlist.
Old 05-30-2008, 07:04 AM
Don Plumley's Avatar
Hi - you say that
the car is running fine, but suddenly having some issues.
Are the issues just the lights?
Since you have a brake warning light, I'd take it moderately seriously. You need a shop that has either the Hammer or PST2 to read the codes and see if it is just an electrical problem. Up in Santa Rosa, I presume that Tillman's can take care of you. In Cotati, De Jung is a good shop as well.
Keep us posted...
Don Plumley
M235i
Old 05-30-2008, 08:07 AM
