-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   G50 External Identification (http://forums.pelicanparts.com/porsche-964-993-technical-forum/411468-g50-external-identification.html)
jd3 05-26-2008 07:12 PM
Pardon my ignorance, but how is a G50 transaxle identified (as much as possible) from an external examination?
Jack
dypascal 05-26-2008 10:47 PM
G50 is fitted with an hydaulic slave and not a cable;the torsion bar axle are longer than the915(if you look in the rear weel bay you'll see a cover for the torsion bar with 4 bolts.If this cover is at least 5 inches long,that's a G50,if almost flush,915) this gear box was introduce in the end of 1986 on 3.2 Carrera.I hope it'll help.
Pascal
Tom W 05-26-2008 11:56 PM
Other than the serial number on the case starts with G50?
