Does the Valves or Valve parts have wear parts to make the valve go out of adjustment
My valves need to be adjusted again , after only maybe 2000 miles.
and before that about 2000 miles after a top end rebuild.
I know this is not normal .
Is there any wear parts that could be wearing or worn causing this.
I need help with this, I have a track event next weekend and they will adjust it again , but what is causing this?
Update,
We pulled the engine , to find the cam lobes and contact surfaces in good shape, it looks like the last guy that worked on it did not adjust correctly
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 06-09-2008, 06:34 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Derek,
Nope, that does not sound normal. Are they getting tighter over time or are they loosening up? If they get tighter that could mean the valve seats wear allowing the valve stems to walk towards the rocker. Maybe a poor valve job. During a top end usually a 3-angle valve grind is done and the valves are ground to the seats by hand as a final step. If this wasn't done properly it could cause the walking.
If they are loosening up over time something (lobe surface, rocker surface, valve stem) is wearing - maye due to an oiling problem. Check the lobe surfaces for wear.
Also, if you are doing your own adjustment make sure you rotate the engine over a couple of times and re-check your valve adjustment. Sometimes the swivel feet need to settle. Use a remote starter switch and it is a breeze.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-09-2008, 08:41 PM
