-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Warm Start Problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/416327-warm-start-problem.html)
cjoenck 06-24-2008 10:56 AM
Warm Start Problem
Hopefully someone can help with this issue I started noticing a few weeks ago. Car starts w/o problem when cold or when hot, i.e after a cold night no issue and after a long freeway drive no issue to start the engine.
However, when the engine is just warm, oil temperature is just above the lowest mark, the engine will not start unless I "help" with a little accelerator support. I get the Engine Warning light but it goes out after a couple of seconds.
Car has new spark plugs, new rotor and new distributor, distributor belt is fine, new oxygen sensor
Initial thoughts were:
- Temperature sensor - checks out fine
- Spark plug wires - check out fine
- Fuel pump relay - checks out fine
Please help. Any idea is welcome.
Thanks!
colo964 06-24-2008 07:28 PM
Could be a bad microswitch, not enough slack in the throttle cable causing the microswitch not to engage, or ISV.
cjoenck 06-30-2008 01:42 PM
Ran the codes today and nothing came up. So, I hope it is a mechanical issue, i.e fuel pressure regulator. Fuel filter is new.... Will let you know if this is it... Parts are on the way.
