has anybody done a transplant of a 986/996 3 or 4 spoke airbag wheel on a 964? will they even fit?
Requires a new steering column. So basically no unless you want to rig it.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
if that is the case then
![]() I guess it would have been too easy... just have to go the the upholstery shop when it needs a new leather cover....
I'm not certain thats the case.. I've seen late 996 wheels installed on 993 cars and as far as
I know 993 and 964 are interchangeable. You can check part numbers of course but they often won't tell you anything other than a part has been superceded. Has Ago25 tried this? Or are the part numbers and columns different? Thanks Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
The 964 steering column needs to be replaced with a 993 version. The 993 column has longer threads for mounting the steering wheel. Although you can mount the steering wheel, you will only be able to catch a few threads on a 964 column (not very safe...some have used loctite to help keep it secure).
BTW, the steering column swap is relatively easy. |
