Blower resister
1. I measured the resistence of my "Blower Resister module" and at room temp and it reads zero ohms. Visual inspection shows both a resister and a set of contacts in parallel. The factory schematic doesnt show the set of contacts. Is this possibly a bimetallic switch which opens at higher temps allowing the resister to come into play? (When I put a hairdryer to mine it didnt open.)
2. What is the value of this resister. (Mine measures 55K ohms but one schematic I saw showed 0.35 ohms.)
Old 07-06-2008, 09:05 PM
kenhill's Avatar
Blower Resistor
Are you referring to the resistor that you use to replace the blower in a 964 if installing a bypass tube?
If so I am interested in what you find out because I am unable to get heat after replacing the blower with the bypass tube.
1991 C2 Coupe
Bilsteins, G&M 6211 HA Springs Lowered 30mm
Primary Exhaust By Pass, Car Bypass, 18" 3 Piece Wheels, HID Lights, Alum Strut Brace, Lightened Fly Wheel, RS Alternator Pulley
Old 07-06-2008, 09:11 PM
Yes. This is the Resister located in the bypass tube. It is used to lower the voltage to the blower to obtain slow speed operation.
Old 07-07-2008, 09:16 AM
Found this from "kenhill": The slow speed resistor is the thing with the spade connectors. The other "probe" thing is a temp sensor.
There was a recent thread on the rennlist.com forum that described what was needed to get the HVAC to work correctly without the fan and sensor in place. It involved connecting a 50 ohm/15 watt resitor in place of the fan motor so that the HVAC controller thought the fan was running.
-doug
Old 07-07-2008, 12:41 PM
Don Plumley's Avatar
Here's a very descriptive DIY.
I've done this in my 993 and everything works just fine.
Don Plumley
M235i
Old 07-07-2008, 01:20 PM
kenhill's Avatar
-doug
My car was built in November '90 and though I have done everything suggested on http://www.porsche964.co.uk/technical/noheater.htm
I am only getting cold air when on the blue dot. I have not been able to get the system give any heat and when switched to heat it simply turns off.
1991 C2 Coupe
Old 07-07-2008, 08:39 PM
The resistor method does not work on the early models. I think the CCU changed sometime in 1991. I was going to try to resistor just to see, however I have not heard of anyone getting it to work with the early models.
1990 964 C4 Cab
2008 Range Rover Sport (daily driver)
Old 07-09-2008, 03:33 AM
