964 Wheel Spacers
I have a used set of 18"turbo wheels coming for my 90 C4, the fronts are 7.5" 50mm offsets, which should be no problem but the rears are 10" 65 mm offset. The only spacers I have found on-line for 964's are 21mm H&R brand DRM's (without removing my original studs) Any other bolt-on spacers out there that are thinner 15 to 18 mm or will these be okay.
Steve new 90 C4 owner |
It depends a lot on the width tire you plan to mount on the wheel, how low your car is, and how much camber you have. If all of these are conservative, the 21mm spacer will probably be fine. You can easily make it thinner by turning on a lathe, too.
Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche |
Platinum Member
Kris, I think Steve meant the spacers that bolt on, then the wheels bolt to them. I would put in longer rear studs.
