swift_964's Avatar
Question on Oil Pressure for 964
Background: '93 964 Manual
Mods include Steve W chip, cup bypass pipe, airbox.
Driving with a friend the other day he looked over (he has a 92 964 aswell) and noticed that my oil pressure gauge registered differently than his. I was wondering what should the gauge register during driving?
What i see is when stopped with the clutch engaged it registers between 2-3 on the gauge. Once i begin moving the pressure rises to just above 4 and hold there while i am driving. If i engage the clutch to come up to a light the pressure will fall from above 4 to 1-2 and level off around 2-3.
Any help would be great thanks!
Old 07-15-2008, 10:52 AM
Looks normal to me.
Whe engine is fully warmed up, and idle rpm dips below 850rpm, it's normal for oil pressure to drop to 1 bar or lower and rises to 2 bars when idle recovers to factory setting.
You have good oil pressure. As long it does not drop below 1 bar enough to trigger the oil pressure indicator light, you are good.
What oil weight is in the car as the oil weight will affect oil pressure esp. when engine is fully warmed up.
Do you ever see the oil pressure indicator light come ON?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 07-15-2008, 02:16 PM
swift_964's Avatar
only 1 time has the pressure light come on. When in heavy traffic and on and off the clutch i have had some issues with the car turning off i.e. idle dropped off too far? I have read that i may need to clean the icv (i think) and will try that this weekend.
Old 07-15-2008, 04:58 PM
Porsche-Poor
bcoats's Avatar
mine is about the same, running 20w-50 oil, Authority chip and primary muffler bypass, also registered same pressure with 15w-40 oil. . .think you're good
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 07-21-2008, 11:00 AM
