having difficulty removing the cutch pedal from the bracket
from my previous thread you wil see i have sufferred wirth a cracked pedal bracket on my 964, as a result i was having difficulty engaging 1st gear.
i have managed to remove the bracket and rather than weld it ill be getting a new one, the only dilema is have been able to remove the brake pedal from the bracket but dont know how to remove the clutch pedal, any tips on how i can do this
Old 09-02-2008, 05:20 AM
Don Plumley's Avatar
According to this DIY, you use a drift punch to push out the shaft.
Don Plumley
M235i
Old 09-02-2008, 08:09 AM
thankyoo, i seem to have aslightly different set up, no bolt to be removed as in the diagram,
Old 09-02-2008, 01:33 PM
