Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
964 clutch pedal what is the adjustment screw on the spring for
i have had to weld my brake,clutch pedal bracket as it cracked due to the tension of the clutch, on the clutch pedal assembly there seems to be a learge spring which i presume gives the tension on the clutch pedal, there is also an adjustment screw directly attached to the spring, what is this screw for can it decrease the tension on the clutch pedal therefore making the clutch lighter
Old 09-06-2008, 03:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Hey 911-2,
I had the same question and learned that the return spring only insures that the pedal returns all the way back up to the return stop. Of course the spring in the clutch pressure plate would return the pedal, so there is no real good reason to even have this spring. It's like an extra maxi-pad to be sure!
Old 09-09-2008, 07:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
after welding my bracket and not disturbing anything else the clutch pedal now sits lower than the brake pedal, dont want to be driving with the clutch not fully released, would adjusting the screw bring the pedal further up so its in line with the brake pedal
Old 09-10-2008, 01:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
That spring there and the adjustment screw does 2 things: when initially pushing down the clutch pedal, the spring helps in making the clutch feel lighter, at the second half of travel the spring helps the clutch comes back up from its bottom position. The factory spec calls for 6mm (i think) of the hex screw to be sticking out. I have adjusted this screw in and out to get the clutch pedal feel I like.
Old 09-10-2008, 05:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
