-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964C2 does not spark (http://forums.pelicanparts.com/porsche-964-993-technical-forum/431016-964c2-does-not-spark.html)
MODIFICH 09-18-2008 01:15 AM
and I can not start engine.
where break?
johnsjmc 09-19-2008 09:40 AM
First thingI assume the engine cranks normalyy. If sothen I would suspect the DME relay($30) .up to about 1990 it,s under the seat beside the DME (computer) itself.I think it then changed to a style with flat pins instead of round and may be in the fusebox with the other relays. A common no spark cause. The flywheel position or referance sensor can be another cause.
