Help Needed - 964 Turbo Reassembly
I hope boeing 717 or one of the other 964 turbo owners can help me here. I am putting my engine back together and I took pictures but one area was covered by a breather hose.
I am trying to figure out the purpose of the 6M x 12 bolt (or if there was a bolt there in the first place) that is threaded into the top of the oil filter housing on the passenger side. I know the other 6M x 12 bolt that is threaded into the engine tin holds the air duct in place. This is holding up production!!! http://forums.pelicanparts.com/uploa...1223391243.jpg Thanks, Mark |
Did you figure this out?
Yes, I did figure it out. I would like to have known where everything goes before I started re-assembly.
So, I started to re-assemble and found out that the 6M x 12 bolt that was threaded into the oil filter bracket connects to nothing. I pulled out the bolt and found another location for it. Maybe another model uses that threaded hole, mine doesn't. Thanks, Mark |
| All times are GMT -8. The time now is 09:56 PM. |
